crankshaft position sensor
Old May 19, 2004 | 12:27 AM
stone150's Avatar
does anyone know where it is located? i got a code so i bought a new one, what is weird is the car runs fine and starts fine, and i have delt with cars that have bad crankshaft position sensors.
Old May 19, 2004 | 12:40 AM
missetti's Avatar
It connects into the bottom of the timing cover.
Old May 19, 2004 | 12:54 AM
LPEdave's Avatar
It's just visible in the lower left corner of this pic - http://www.go-fast.org/z28/MyParts/crankseal1.jpg
White connector with wires going in to it. The hub is off the crank in that pic, but you don't need to remove the hub to change the sensor.
Dave
Old May 19, 2004 | 08:16 AM
Another visual. Most other cars will not run with a bad crank sensor. The LT1 is different, in that it gets position info from the optispark for ignition purposes. The crank sensor is only used for detecting misfires.
Old May 19, 2004 | 01:45 PM
stone150's Avatar
so it looks like it is not a difficult install, what is weird is theat the car juns just fine.
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
