crankshaft bearings??
Old Sep 12, 2013 | 09:56 PM
ChevyBoy6155's Avatar
so i guess the crankhaft bearings are bad in my lt1.
whats the whole process of replacing them?
and costs if you have any idea..
thank u
Old Sep 12, 2013 | 10:23 PM
Mr99SS's Avatar
Re: crankshaft bearings??
if the bearings are really bad the crank will have to be cut down , and u will have to use over sized bearings .... if not to bad you might can get away with just polishing the crank.
Different machine shops have different prices
low oil pressure ? do you hear knocking ?
if it has high miles and regular crank rods pistons , it be cheaper to buy a lower mile engine out of a junkyard
Old Sep 12, 2013 | 10:34 PM
Sounds like you are really not sure of what you have wrong. The engine has to be totally torn down to replace crank bearings.
Old Sep 12, 2013 | 11:30 PM
97WS6SCharged's Avatar
Depends on how much damage has been done. Best case you can polish the crank as mentioned and use a standard bearing. Worst case you need a new crank and the block needs a line bore. Either way you won't know until it's stripped and miced.
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
