cranks but won't start after rebuild
Old Apr 24, 2010 | 11:27 AM
railroaders94z's Avatar
Have 94 z28 rebuilt the lt put together went to fire cranks very erratic but won't start.Has compression,fuel and spark.I also checked to see if 180 out and had starter tested works fine on test rack but in car just spins starts stops plunges in and out.pulled away from flywheel same thing.Has new opti,starter,cam,water pump.to much to list.Can anyone help with this wall I have run into?
Old Apr 24, 2010 | 12:29 PM
Are you sure you have the Opti splined driveshaft indexed correctly? Have you scanned it for codes?
Old Apr 24, 2010 | 01:38 PM
thats a roger I thought that to maybe off a tooth checked twice.
Old Apr 24, 2010 | 01:40 PM
have not scanned yet for codes.
Sergio
Jan 27, 2016 04:27 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
