Crankcase filling with gasoline
Old Mar 4, 2013 | 04:04 PM
Ryan Posey's Avatar
My car is filling the crankcase with gasoline very quickly. Where is the best place to start trying to diagnose this problem? THANKS
Old Mar 4, 2013 | 04:08 PM
Re: Crankcase filling with gasoline
Check the vacuum compensation line from the fuel pressure regulator for wet fuel. Should not be wet.
Does the exhaust smell extremely rich? The injectors could be flooding the cylinders, with the excess fuel bypassing the rings, into the crankcase.
KW Baraka's Avatar
Either your injectors are spraying waaaaaay too much fuel, or you have cylinders that are not firing.
Check spark plugs for signs of excessive wear/breakage and for fouling.
Also.....scan it while running to determine if all cylinders are firing and check fuel pressure.
KW
Old Mar 4, 2013 | 04:14 PM
Ryan Posey's Avatar
ts obdI so i don't have a compatable scan tool. I pulled the rails and injectors out and turned the key on and found no leakers. I have not tried to pop them off and watch them yet.
Old Mar 4, 2013 | 04:16 PM
KW Baraka's Avatar
Originally Posted by Ryan Posey
........I pulled the rails and injectors out and turned the key on and found no leakers. I have not tried to pop them off and watch them yet.
I'd expect at least one injector being stuck in the open position.....
KW
Old Mar 4, 2013 | 04:17 PM
Ryan Posey's Avatar
I did too, however no leaks.
Old Mar 4, 2013 | 04:21 PM
Ryan Posey's Avatar
I already pulled vacuum on the regulator and it held.
Old Mar 4, 2013 | 04:22 PM
Ryan Posey's Avatar
Also it's a bone stock 1994 model
Old Mar 4, 2013 | 04:24 PM
Check the vacuum line from the EVAP purge solenoid for wet fuel.
Old Mar 4, 2013 | 04:29 PM
Ryan Posey's Avatar
evap purge is dry
Old Mar 4, 2013 | 04:41 PM
You need to use the fuel pump prime connector and keep the pump on when you check. When you hit the key and don't start it, the pump only stays on for a couple of seconds. Other factors may be relieving pressure.
If you are getting as much gas in the crankcase as what you are saying, it almost has to be injector or f/p regulator related.
Old Mar 4, 2013 | 04:49 PM
Ryan Posey's Avatar
ground it or B+ to it?
Old Mar 4, 2013 | 05:14 PM
+12v
Old Mar 4, 2013 | 06:51 PM
Ryan Posey's Avatar
+12v
I pulled the rail and wrapped baggies around each injector. One would work fine for about 6 pulses then it began to spray wildly.
Old Mar 5, 2013 | 12:17 PM
KW Baraka's Avatar
Originally Posted by ryan posey
i pulled the rail and wrapped baggies around each injector. One would work fine for about 6 pulses then it began to spray wildly.
And there you have it ........
KW
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
Pwilson59
Sep 3, 2015 08:47 PM
Aug 24, 2015 06:41 AM
alphaauto
Jul 26, 2015 04:40 PM
RX Speed Works
Jul 24, 2015 02:25 PM
