Crankcase filling with gasoline
My car is filling the crankcase with gasoline very quickly. Where is the best place to start trying to diagnose this problem? THANKS
Re: Crankcase filling with gasoline
Check the vacuum compensation line from the fuel pressure regulator for wet fuel. Should not be wet.
Does the exhaust smell extremely rich? The injectors could be flooding the cylinders, with the excess fuel bypassing the rings, into the crankcase. |
Either your injectors are spraying waaaaaay too much fuel, or you have cylinders that are not firing.
Check spark plugs for signs of excessive wear/breakage and for fouling. Also.....scan it while running to determine if all cylinders are firing and check fuel pressure. KW |
ts obdI so i don't have a compatable scan tool. I pulled the rails and injectors out and turned the key on and found no leakers. I have not tried to pop them off and watch them yet.
Originally Posted by Ryan Posey
(Post 6934660)
........I pulled the rails and injectors out and turned the key on and found no leakers. I have not tried to pop them off and watch them yet.
KW |
I did too, however no leaks.
I already pulled vacuum on the regulator and it held.
Also it's a bone stock 1994 model
Check the vacuum line from the EVAP purge solenoid for wet fuel.
evap purge is dry
(Post 6934660)
If you are getting as much gas in the crankcase as what you are saying, it almost has to be injector or f/p regulator related. |
Originally Posted by shoebox
(Post 6934670)
You need to use the fuel pump prime connector and keep the pump on when you check. When you hit the key and don't start it, the pump only stays on for a couple of seconds. Other factors may be relieving pressure.
+12v
(Post 6934675)
+12v
Originally Posted by ryan posey
(Post 6934684)
i pulled the rail and wrapped baggies around each injector. One would work fine for about 6 pulses then it began to spray wildly.
KW |
