crank sprocket
Old Jul 22, 2013 | 08:31 PM
1FST4GEN's Avatar
crank sprocket
Will not flippin come off! Is there a trick to it or what cause mine seems to not want to move
Old Jul 22, 2013 | 09:10 PM
97 6SPEED Z's Avatar
Question Re: Crank Sprocket
What type of puller are you using?
You do know it's pressed on ...... right?
Old Jul 22, 2013 | 09:19 PM
1FST4GEN's Avatar
Re: crank sprocket
Sprockets pressed on? Since when?
I know hub is but im doing cam and if im correct the crank and cam sprocket should slide right off after cam gear is unbolted correct?
Old Jul 22, 2013 | 09:35 PM
Post Re: crank sprocket
Regarding the "since when" question ......... for small block Chevys ..... I'm pretty sure ...... since 1955.
And finally, nope, the crank sprocket will NOT just slide off after the cam sprocket and timing chain have been removed. Again ...... you need a puller to remove the crank sprocket.
Old Jul 22, 2013 | 09:42 PM
PA94Z's Avatar
Re: crank sprocket
To add to this, you also need a way to press the new one on. What works well is a short 3 or 4" long piece of pipe and a crank hub installer set.
Old Jul 22, 2013 | 11:09 PM
Re: crank sprocket
I see an educational opportunity here, LOL.
Old Jul 23, 2013 | 01:19 AM
97WS6SCharged's Avatar
Re: crank sprocket
I always used a hub install tool (all thread) with a piece of pipe and some washers to press my sprocket into place.
Old Jul 23, 2013 | 07:59 AM
Re: crank sprocket
It generally take little effort to put a crank gear on.
Old Jul 23, 2013 | 08:16 AM
Shangrila's Avatar
Re: crank sprocket
Like the others said, use a puller and maybe apply a little heat to it if it's giving you a lot of trouble. Installing was easy, I didn't want to bang on it with a hammer so I put the gear into the toaster oven for 15 minutes on high and it went on really easy with minor tapping.
Old Jul 23, 2013 | 09:53 AM
1FST4GEN's Avatar
Re: crank sprocket
Yup definatly not a ford lol thank you for the pic shoebox
Old Jul 26, 2013 | 08:56 AM
Bersaglieri's Avatar
Re: crank sprocket
Pour on that learning shoebox!
13qtr
Oct 28, 2016 08:11 PM
Jeff1904
Jun 5, 2016 05:00 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
