crank question
Old Oct 6, 2004 | 03:25 PM
The Cartel's Avatar
crank question
I'm using a stock crank for my 355. I have noticed on my old crank it has a brass looking fitting in the rear end for the little trans shaft to fit in while the one I'm using has little a little needle bearing? Both cranks are out of a 6 spd car and my question is which do I use? Where do I get a new one? I'm pretty sure that I'll tear up the brass one if I try to get it out of the old crank, and the newly machined one looks like it was missing a couple needles in the bearing...WTF
Jason
Old Oct 6, 2004 | 04:26 PM
944v8inDFW's Avatar
Re: crank question
1994-1997 clutch pilot roller bearing part number 14061685 $7.47 Make sure it is in good shape I would for sure put in a new one. I once tore a car apart to replace one. That sucked as i was in a hurry to get er done.
Old Oct 6, 2004 | 04:37 PM
The Cartel's Avatar
Re: crank question
thank you so much, I was afraid no one would know what the hell I was talking about. I'll get a new one for sure....
Jason
Old Oct 6, 2004 | 04:39 PM
944v8inDFW's Avatar
Re: crank question
np
always happy to help
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
