Crank question
Old Dec 26, 2003 | 09:42 PM
94TA_LT1's Avatar
Crank question
Anybody know if a LT1 crank will fit in a 96 chevy vortec 350 truck motor?
Old Dec 26, 2003 | 10:47 PM
nitropatch's Avatar
it should because LT1's rotating assembly is pretty much the same as the older 350s but the motor has to be a 1 peice rear main seal.
Old Dec 26, 2003 | 11:00 PM
94m5's Avatar
Yes, I will "fit". But if your gonna put another crank in an engine, I would HIGHLY recommend having the entire reciprocating assembly balanced before putting everything back together. You'll get a MUCH smoother reving, and longer running engine.
Mike
Old Dec 26, 2003 | 11:35 PM
94TA_LT1's Avatar
thanks for the help. My truck needs a new crank so i was tinking about building 383 for my trans am and using my stock crank in the truck.
Old Dec 27, 2003 | 11:35 PM
94TA_LT1's Avatar
will the balance still be right since the LT1 pistons are lighter than the truck pistons?
Old Dec 28, 2003 | 12:16 AM
94m5's Avatar
It does'nt matter as far as I'm concerned. ANY time I do any internal engine work, I have the reciprocating assy rebalanced to make sure. It's been worth it everytime.
Old Dec 28, 2003 | 01:22 AM
94TA_LT1's Avatar
how much does that cost. who can do it?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
