Crank Question
Old Nov 30, 2003 | 07:14 PM
AlmostfastLT1's Avatar
Crank Question
I am build a new motor and punching it out to a 355ci. I want to know what is the stock stroke. I am using of course a 5.7 rod.
I am trying to order the crank tomorow and need the specs.
Also, what do you all think of the crank listed above, how stronge it is , weight, etc.
Old Nov 30, 2003 | 07:24 PM
slopokrodrigez's Avatar
Stock stroke is 3.480" which many call 3.500".
Old Nov 30, 2003 | 07:38 PM
amean94ta's Avatar
slopokrodrigez you never got back to me about you calling the counter weights on the crank "bobweights" see i was just trying to inform you that you were wrong
Old Nov 30, 2003 | 09:40 PM
ttt
Old Dec 1, 2003 | 05:13 AM
How old are you?????? First of all stop wasting other peoples threads. If you had to inform of something trivial, then PM me. Second of all, the weights on cranks were called bob-weights long before you were born. Old habits are hard to shake. Third, get a life.
Old Dec 1, 2003 | 05:31 AM
97WS6SCharged's Avatar
Which crank are you planning to use?
Old Dec 1, 2003 | 08:48 AM
Lightweight, 3.480'' Stroke with 2 Piece Rear Seal, 5.7''/6.0'' Rod, Internal Balance, 2.100'' Rod Journal
Old Dec 1, 2003 | 10:01 AM
ttt
Old Dec 1, 2003 | 10:06 AM
RacinLT1's Avatar
you need a 1 piece rear main seal crank for the LT1,unless you want to run an adaptor.
Old Dec 1, 2003 | 11:11 AM
how much for the adapter and problems with install
Old Dec 1, 2003 | 11:20 AM
RacinLT1's Avatar
dont remember how much the adaptor is,and the biggest problem is they are prone to leaking.
better off buying a 1 pc rear seal crank
Old Dec 1, 2003 | 01:28 PM
Thanks for the info, i am still thinking of the old school cranks
Old Dec 1, 2003 | 08:23 PM
There was a reason for engineers to switch ALL engines after 1986 to a one piece rear seal. Can you spell LEAKS. Not to mention getting a flywheel to fit new engines with an old crank. You really need to talk to the guys at Nu-tek and then consider the 1 piece rear main seal Dragon slayer crank from Calies.
Old Dec 1, 2003 | 10:12 PM
amean94ta's Avatar
or eagle
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
