Crank Question
Crank Question
I am build a new motor and punching it out to a 355ci. I want to know what is the stock stroke. I am using of course a 5.7 rod.
I am trying to order the crank tomorow and need the specs.
Also, what do you all think of the crank listed above, how stronge it is , weight, etc.
Originally posted by amean94ta
slopokrodrigez you never got back to me about you calling the counter weights on the crank "bobweights" see i was just trying to inform you that you were wrong
There was a reason for engineers to switch ALL engines after 1986 to a one piece rear seal. Can you spell LEAKS. Not to mention getting a flywheel to fit new engines with an old crank. You really need to talk to the guys at Nu-tek and then consider the 1 piece rear main seal Dragon slayer crank from Calies.
Brandon Wittmer
Dec 20, 2014 09:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
