crank pulley
Old Nov 19, 2007 | 06:11 PM
red1997blazer's Avatar
crank pulley
Please clarify this for me. I am under the impression that the stock lt1 crank pulley has a built in damper(or all in one pulley/harmonic damper). Yes or no?
Old Nov 19, 2007 | 06:18 PM
Built LT1's Avatar
Yes, it does. Were you just needing an answer to this question or are you wondering how an underdrive pulley system works with an LT1?
Old Nov 19, 2007 | 06:49 PM
I was just making sure the previous owner of my engine didn't part the harmonic damper off of the engine without telling me.
Because, from what I've been reading about underdrive crank pulleys I started to think the damper and crank pulley were two different entities. So when I looked at my crank pulley and all I seen was a pulley I got a little worried.
Thanks for letting me know the stock pulley and damper were one in the same. But aftermarket stuff is one or the other, unless specified correct?
Old Nov 19, 2007 | 07:10 PM
speed_demon24's Avatar
The only underdrive pulley (besides the SFI dampners) that has is a dampner too is the ASP 23% pulley, all of the other ones just piggy back onto the stock pulley.
Old Nov 19, 2007 | 09:07 PM
greenmachinedriver's Avatar
well the stock lt1 damper/pulley assembly is three pices. the hub that bolts onto the crankshaft and seals against the front cover seal, the pulley which is sandwiched in between the hub and damper, and the damper itself which has three bolts in it holding the damper and pully to the crank hub. all the aftermarket under drive pulleys that i have seen just replace the pulley in between the hub and damper.
Old Nov 19, 2007 | 09:10 PM
That's not a stock setup, theres a hub then pulley that bolts to the hub. Nothing else.
Old Nov 19, 2007 | 09:19 PM
i thought my car was 100% stock when i bought it and i have worked an a few other lt cars and they all had a 3 pice design. the damper has ribbs on the outside like a pulley but is not used. the pulley that actually drives the belt is seperate and much smaller than the damper. maybe i am wrong, do i have an underdrive pulley? anyone got pics of a stock setup?
Old Nov 19, 2007 | 09:59 PM
well after some quick research i stand corrected. i am amazed i have had the car for five years and never realized. this must be why my ac sucks at idle.
Old Nov 20, 2007 | 11:01 AM
Shoebox has a photo of everything....
http://shbox.com/1/pull_pulley.jpg
jbert55
Oct 31, 2015 03:52 PM
truthmatters
3rd Gen / L98 Engine Tech
Aug 19, 2015 04:09 PM
4586
Aug 18, 2015 07:08 AM
Slayer
Aug 17, 2015 03:55 PM
Catmaigne
Jul 14, 2015 05:17 PM
