Crank postion sensor question?
Old Feb 7, 2008 | 09:16 PM
RedWS6TA's Avatar
does anyone know if an obd2 car will run with the cps unpluged? in the past i have been able to grind on the reluctor ring and the timing cover and make enough clearance to run a double roller but with this motor i cant seem to get it right. so if i leave the reluctor ring out and just unplug the senor would it run until i can covert to obd1?
Old Feb 7, 2008 | 09:18 PM
mdacton's Avatar
it will run...it will set of the mil but it will start up and run without it if thats what your asking
Old Feb 7, 2008 | 09:19 PM
RedWS6TA's Avatar
yes thanks. running the light wouldnt be a problem for now. i can covert it later. thanks alot
Old Feb 8, 2008 | 11:26 AM
96flame's Avatar
You will need to use the reluctor ring as a spacer to keep the pulley aligned properly or get a crank hub from a pre OBDII. I've heard of guys grinding the ring down to just the crank diameter to use it as a spacer.
Old Feb 8, 2008 | 11:28 AM
mdacton's Avatar
ATI sells the spacers, I just get those.......its just easier, one less thing to deal with
HectorM52
Jul 30, 2017 11:46 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
