Crank position sensor code
Old Jan 21, 2005 | 10:04 PM
cjksflorida's Avatar
My car is currently at the shop and they informed me one of the codes was the crank position sensor faulty. From doing searches on this subject I can't find clear consensus of wether or not my car has a crank position sensor or not. Any help on this matter would be greatly appreciated. I have a 94 Z with the OBD1 computer. Thanks in advance.
Old Jan 22, 2005 | 12:35 AM
bowtiethunder's Avatar
Re: Crank position sensor code
I think you need to find a new shop, no crank postion sensor on your car.
Old Jan 22, 2005 | 01:18 AM
I would agree with that. F-body cars did not have crank position sensors until 1996. Maybe they mean an optispark code. Get the exact code number from them.
Old Jan 22, 2005 | 10:47 AM
I just talked to him and he said that it was code 18 (fuel injector circuit) or something. Any suggestions on what would cause that code. Thanks.
Old Jan 22, 2005 | 01:28 PM
Anyone got any ideas?
Old Jan 22, 2005 | 01:43 PM
One of you injectors has a faulty electrical circuit. Unplug each injector, key on, engine not running. Check each pink wire on the injector for +12V. Then check the resistance across the pins of each injector for 12-15 ohms resistance. If you pass these two tests, reconnect the injectors, start it up, get a noid light and use it on each injector to verify that the PCM is supplying the ground to fire the injector.
Old Jan 22, 2005 | 05:19 PM
Latest update, Car was running very bad...using alot of fuel. Turns out the #8 injector harness was a little out of wack and wasn't firing any fuel into the cylinder. Had it fixed and now runs like a champ. It has a small hardly noticeable miss, but I'm not sure if that's a fouled plug or from the CC306 cam. But all and all it is running very well now, and I am as happy as can be with my Z now.....finally. Thanks for all the help from you all, you guys always manage to help a fellow enthusiast out when it's needed. Thanks again.
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
91Bird305
Aug 5, 2002 01:39 PM
