crank HUB TDC arrow???
Old Apr 25, 2006 | 07:08 PM
Hawk's Avatar
My question, short and easy.
Do I have to take off the crank hub pulley to see the crank hub arrow for TDC??? Or is it located where I can see it with the pulley on? I don't want to use the pulley "dot" because I've had it off before and it's probably not orientated right.
Brian
Old Apr 25, 2006 | 07:30 PM
sabre81's Avatar
Re: crank HUB TDC arrow???
The arrow is on the pulley.
Old Apr 25, 2006 | 07:48 PM
Hawk's Avatar
are you sure, I read somewhere that there is a mark on the CRANK HUB(cast into the HUB) and a dot on the pulley???
Old Apr 26, 2006 | 07:29 AM
Hawk's Avatar
Ttt
Old Apr 26, 2006 | 07:55 AM
Stoopalini's Avatar
The arrow is cast onto part # 42 in this pic, between two of the mounting holes. (pic thanks to Shoebox)
Be aware, the hub is not keyed; so it can spin on the crank causing it to be off from TDC.
Thomas.
Old Apr 26, 2006 | 08:17 AM
Hawk's Avatar
Thomas.
Ok, well I thought it was also on part #45, looks like they even show an arrow on it in the diagram.
I might pull the pulley and look, just cuz I'm curious..............
Old Apr 26, 2006 | 08:23 AM
Stoopalini's Avatar
I did not see a mark on part #45 when I replaced my timing cover seals/gasket; although I wasn't really looking either. The mounting holes are slightly offset though, which allows for part #42 to only go on #45 in one orientation.
Thomas.
Old Apr 26, 2006 | 08:56 AM
BlackScreaminMachine's Avatar
The arrow is also on the hub itself
Just did a cam swap and I saw it on a 94 LT1 motor
Old Apr 26, 2006 | 12:05 PM
There should also be a mark or cast line in the hub that relates to where the arrow is on the pulley.
Old Apr 26, 2006 | 12:09 PM
Javier97Z28's Avatar
Moderator
Yah, looks kinda like a bump b/w the two ears.
Old Apr 26, 2006 | 01:32 PM
Hawk's Avatar
thanks for the wealth of info.
Looks like good news because I've never had the crank HUB off and I can use the mark on their to find TDC. I'm just using it for valve lash, doesn't have to be 100% accurate.
Old Apr 26, 2006 | 01:41 PM
follow shoebox's valve lash guide depending if your TDC compression or TDC exhaust
Old Apr 26, 2006 | 01:47 PM
Hawk's Avatar
I am, I borrowed a compression guage to put in the #1 cylinder to see if I'm on compression stroke.
Old Apr 26, 2006 | 02:07 PM
awesome, go for it :thumbup:
AviatorDave
Dec 19, 2016 06:35 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 24, 2015 10:47 AM
Catmaigne
Jul 14, 2015 05:17 PM
