crank hub....seal wear marks?? (pics)
Old May 31, 2010 | 02:49 AM
z28beast's Avatar
ok so i have marks on my crank hub that seem to be from the seal rubbing on it for so long... is this normal? its not deep but i can deff. feel it when i rub my finger nail across it....
here are the pics...sorry the camera is a Nikon cool-pos........also do the heads on my motor appear to be the stockers? i dont know if they are or not.
http://img267.imageshack.us/gal.php?...ropics2049.jpg
Old May 31, 2010 | 09:02 AM
Check the casting numbers on the heads.
Old May 31, 2010 | 09:22 AM
Stl94LT1's Avatar
Yes, normal.
Old May 31, 2010 | 11:26 AM
Doesn't that pic look like the hub already has a repair sleeve on it or is it my eyes? He could just remove and replace the repair sleeve.
Old May 31, 2010 | 12:27 PM
Stl94LT1's Avatar
Yes it does. Initially I didn't even look at the pic.
Old May 31, 2010 | 12:44 PM
z28beast's Avatar
ok so how do i replace the repair sleeve? is it a part i can get at autozone? and how much is it usually
Old May 31, 2010 | 12:45 PM
z28beast's Avatar
what are the numbers for stock heads?
Old May 31, 2010 | 04:17 PM
Several versions, all covered in this thread:
https://www.camaroz28.com/forums/sho...d.php?t=427346
Old May 31, 2010 | 06:38 PM
z28beast's Avatar
ok thanks injuneer...but as far as the hub what do i do?
Old May 31, 2010 | 06:55 PM
Don't know about the cost, but the repair sleeves are available at most auto parts places.
Old Jun 1, 2010 | 10:50 PM
z28beast's Avatar
does it look like i need one forsure or no?
Old Jun 2, 2010 | 07:46 AM
It's hard to judge from a picture. It does not look all that bad, but if it was real cheap, I'd probably replace it. Your call.
Old Jun 5, 2010 | 08:15 AM
OneShoe50's Avatar
Save yourself some grief and replace it, it's apart, IMO when in doubt swap it out it's cheap enough and will be one less thing to worry about.
Hey, good pictures also!
Old Jun 5, 2010 | 08:53 PM
slowride94z's Avatar
http://www.autozone.com/autozone/cat...&parentId=51-0
do it 8.99$ here
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
ChrisFrez
Dec 7, 2014 11:32 AM
Z284ever
57
Aug 4, 2002 03:48 PM
