Crank Hub removal...
Old May 9, 2010 | 07:28 PM
19z28camaro02's Avatar
Trying to take the Hub off of my crank, I removed the three bolts and everything I've read says it just comes right off, no. Tapped it with a hammer, no. Any helpful hints are much appreciated.
Old May 9, 2010 | 07:44 PM
ACE1252's Avatar
You will need a puller. It's an interference fit with the crank.
There are several threads on how to pull it. It's also on Shoebox's site.
Wait...are you talking about the damper or the hub? The damper bolts to the hub and can get rusted to it.
Old May 9, 2010 | 07:47 PM
Damper, I removed the three bolts that hold it, left the center one in that holds the snout, I'm just puting on an underdrive pulley.
Old May 9, 2010 | 07:52 PM
ACE1252's Avatar
Use a good penetrating oil where the hub and damper meet. Rap the 3 prongs of damper with a hammer. You can rap on the outer edge of the damper, but don't get crazy with it. If that does not get it you may have to get a puller for prongs(I would not use a puller on the outer edge of the damper...could destroy it).
Hehe, make sure it does not hit you when it finally moves.
Old May 9, 2010 | 08:12 PM
RamAir95TA's Avatar
Use a 3-jaw puller with the claws on the inside of the pulley.
AviatorDave
Dec 19, 2016 06:35 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 24, 2015 10:47 AM
Catmaigne
Jul 14, 2015 05:17 PM
