crank hub removal
Old Nov 7, 2008 | 07:39 AM
  #16
whyrun's Avatar
I've never had on spin And I've done it so many times it at funny.. I guess its got alot to do with the foot lb of the gun your using I guess? If you left the flywheel on you can wedge a block of wood behind it and the engine stand maybe.
Old Nov 10, 2008 | 12:20 AM
  #17
luckyou03's Avatar
I chained the hub. Here is my writeup for this: http://www.lt1engine.com/tech/remove...lt1-crank-hub/
Old Nov 10, 2008 | 02:52 AM
  #18
Green96Z's Avatar
I wouldn't recommend using a bolt to pull the hub onto the crank, you can damage the threads like that. Build yourself one of these, mine worked perfect:
http://members.***.net/gmarengo/Misc/Misc.htm
Using that tool, you don't have to worry about the crank spinning.
Old Nov 10, 2008 | 03:20 AM
  #19
luckyou03's Avatar
That link is on that page.....
Old Nov 10, 2008 | 06:47 AM
  #20
I wouldn't recommend using a bolt to pull the hub onto the crank, you can damage the threads like that. ...
X2. Bad idea.
Old Nov 10, 2008 | 09:23 PM
  #21
luckyou03's Avatar
I wouldn't recommend it either and the page never says to do that...
Old Nov 10, 2008 | 10:07 PM
  #22
SS RRR's Avatar
Originally Posted by shoebox
Wedge a block of wood between the flywheel and the engine block.
.... or there are holes in the flywheel that you can put a screw driver through...
Old Nov 11, 2008 | 06:54 AM
  #23
The instructions also say it is ok to thread a bolt into the crank and push against that. I also would not do that, unless the bolt is tapered on the threaded end so it won't bind in the bottom of the hole. It must be threaded all the way in and bottomed out, so that no pressure is exerted on the threads.
I would not ever use a jaw puller on the hub, either. Ask the people that have snapped an ear off the hub doing that (turning the job into a major problem). I would not feel comfortable recommeding those instructions. Too many potential pitfalls.
Old Nov 11, 2008 | 03:03 PM
  #24
luckyou03's Avatar
That's fine, don't. I've done this method more that 4 times with no problems ever. The methods used here were by me and if you use a different method that is fine, this is just what has worked well with me.
What do you mean also says? If implying I recommend using a bolt to pull the hub onto the crank like that other guy said. That's incorrect.
I've removed the hub by backing out the crank bolt before and pushing on it when it was in only a few threads. (as alot of people have done, which I don't recommend) I'm completely confident that if a bolt was in all the threads and not tapered, it wouldn't hurt anything.
The people that have broken off an ear were either pushing on the hub itself and creating a bind or were pushing on the hub bolt while it was still tight. If you insert a longer bolt as instructed, you won't break off anything.
Old Nov 11, 2008 | 03:22 PM
  #25
That's fine. I've done this method more that 4 times with no problems ever. The methods used here were by me and if you use a different method that is fine, this is just what has worked well with me.
I've removed the hub by backing out the crank bolt before and pushing on it when it was in only a few threads. I'm completely confident if is a bolt was in all the threads in the crank it wouldn't hurt anything.
I'm sure those that have posted about stripped threads don't share your confidence.
I understand it was based on your experience. That's ok with me. The beauty of good instruction is that anyone can follow it with little to no chance of causing any further problems. I see too many people take advice that causes them more pain. It takes a lot of effort to plan for any contingency.
Old Nov 11, 2008 | 03:24 PM
  #26
Perhaps, perhaps not, but a jaw puller is the wrong tool for the job.
Old Nov 11, 2008 | 04:09 PM
  #27
luckyou03's Avatar
I have revised the article and included some of your suggestions.
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
