83 carbed lt1
Old Sep 12, 2004 | 06:02 PM
lt1g3n's Avatar
83 carbed lt1
Hey guys, haven't been on the forum for awhile, i finally have everything hooked up and the thing cranks and cranks and cranks, im getting fuel from my inline fuel pump, to the carb definately, i tried testing for spark, and i didnt see any spark what so ever :/ , i changed my ignition coil inside the distributor, still no spark, i tested the hot wire to the coil to make sure it had a full 12 v, it did. Do i need to replace my whole bottom part of the distrubutor maybe? oh yea i replaced the cap n rotor as well. spark plugs and wires as well. still no spark , and its just flooding the car cuz it wont blow up me gas ..
Well any help would be gladly appreciated
i am using a rear mount distributor now that i switched to carb, thanks.
Old Sep 12, 2004 | 08:18 PM
Max 93's Avatar
Re: 83 carbed lt1
are you running a hei? If you are, check the wires at the pickup coil in the distributor, they might be broke off.
Old Sep 12, 2004 | 09:19 PM
lt1g3n's Avatar
Re: 83 carbed lt1
yeah the wires are fine
Old Sep 12, 2004 | 10:34 PM
IrocSS85's Avatar
Re: 83 carbed lt1
what about the ign. module? thats the thing with the wires in the bottom of the distr.. sure its good? if it goes out, no spark. there's a way to test it, I believe its resistance related, but cant remember what the resistance should be. is this a new distr. or a used/old one?
Old Sep 13, 2004 | 12:39 AM
blwnlt4's Avatar
Re: 83 carbed lt1
sounds like the ignition module, take it to a auto parts store to get it tested(i know advance auto parts has the tester for it)
Old Sep 13, 2004 | 09:25 AM
lt1g3n's Avatar
Re: 83 carbed lt1
u talking about the module in the cap? thats brand new, i even used another one i had laying around still no go, but it is an old distributor, all i replaced was the module inside of it, and the cap n rotor
Old Sep 13, 2004 | 08:31 PM
IrocSS85's Avatar
Re: 83 carbed lt1
what about the coil inside the distr.? its in the center of the distr. next to the module. maybe that is bad. I wouldnt mess with it myself. I'd just buy one of those pertronix dist.s if you dont have the money for an MSD or mallary dist.
Old Sep 13, 2004 | 08:43 PM
lt1g3n's Avatar
Re: 83 carbed lt1
figured out what it was, my pick up coil is bad, the car started when i removed the 4 pin connector from the ecm to the dist... that means the pick up coil is bad, says chiltons :P thanks guys
Old Sep 13, 2004 | 09:02 PM
IrocSS85's Avatar
Re: 83 carbed lt1
thats the one. sweet.
bose
Jan 30, 2015 02:36 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
