Crank Hub Puller
Old Oct 5, 2005 | 03:31 PM
978Racing's Avatar
Crank Hub Puller
Hello,
Trying to change my cam on my 93 LT1 motor. Have removed the harmonic balancer but cannot find the correct puller to remove the crank hub. It will take a sturdy puller for the job??
Appreciate anyones help,
AL
Old Oct 6, 2005 | 02:18 PM
ChevyTuffD.A.'s Avatar
Re: Crank Hub Puller
Any tool that is made to pull off a hub should work. Did u take the hub bolt out and put a 3" Allen head bolt in there so that the puller has something to push off against. Either the steering wheel/balancer puller or the claw type puller would work.
Old Oct 6, 2005 | 02:22 PM
Z95m6's Avatar
Just go get you a "crowsfoot" puller. It'll work fine.
Old Oct 6, 2005 | 05:29 PM
978Racing's Avatar
Thanks to both responses. The allen head bolt is a great suggestion. I should be able to get it with that.
Appreciate the advice.
AL
AviatorDave
Dec 19, 2016 06:35 PM
95craz28
11
Sep 12, 2015 07:47 AM
4586
Aug 18, 2015 07:08 AM
Boss002
Jul 24, 2015 10:47 AM
Catmaigne
Jul 14, 2015 05:17 PM
