What causes a bunch of false KR?
Old Oct 5, 2005 | 03:44 PM
speed_demon24's Avatar
Sometimes when I'm driving my car I can't get any kr at all, no matter what (I know this is a good thing), but other times, whenever I touch the gas pedal I get anywhere from 8-12 degrees of KR. Is my knock sensor going bad? I have an LT4 KM, and no major exhaust leaks....
Old Oct 5, 2005 | 04:47 PM
hawk232's Avatar
Re: What causes a bunch of false KR?
everytime i get false KR its always from the exhaust hitting the frame somewhere, fix that and it goes away. last time i got tired of fixing it so i just de sensitized the KS
Old Oct 5, 2005 | 05:05 PM
My exhaust isn't hitting anywhere, its something in the pcm or something, or mabey the KR is going bad. What are the signs of a bad knock sensor.
teke184's Avatar
bad gas?
bad tune?
Old Oct 5, 2005 | 06:04 PM
Originally Posted by teke184
bad gas?
bad tune?
It's not the gas, sometimes its fine on the same tank, othertimes i get a ****load of false KR. And I don't think anything is wronge with the tune if it only does it sometimes....
Old Oct 5, 2005 | 08:30 PM
1racerdude's Avatar
LT4 KM will only tune out what it is programed to. If ya got RR's or exhaust noise the LT4 KM don't help.
Any noise it isn't tuned for will cause retard.
Do the resistor and be done with it or have it removed from your computer.
Old Oct 5, 2005 | 10:45 PM
If it is repeatable under the same exact conditions, it may not be false at all.
Old Oct 5, 2005 | 11:00 PM
Why would the LT4 knock module not help with "RR's"? That's specifically what its tuned to filter out.... the noise from the Crane Gold 1.6 RR's used on the LT4 engine.
Old Oct 5, 2005 | 11:28 PM
1racerdude's Avatar
The Cranes I don't know about but the Comp,Crower,and 1 set of T&D's that I have used with the factory computer will trigger retard and it seems that header's trigger it also.Every car I have put header's on long or short has KR when it didn't have before. Doesn't seem to matter on the type of exhaust. That's with nothing hitting and no leaks.
Hell I had one customer that had installed one of those boom boom stereo's and said it didn't run right anymore,come to find out without the sound's on it was fine but when ya started rattling the license plate with it a bunch of KR would appear.Sooooo I just automatically install the resistor and tell them not to get gas at an all night Conoco station.
EDIT: This is after trying the LT4 module on a several before them.
Old Oct 6, 2005 | 07:14 AM
Trust me, there's no way im gettin 12-13 degrees of kr at 1/4 pedal, then the next day on the same exact tank of gas in the same weather conditions, I wont even see .1 degrees of KR. What are the signs of a bad knock sensor?
Old Oct 6, 2005 | 12:24 PM
Red on Red WS6's Avatar
Are you using the AC while you get this knock? If so it could be a bad bearing for the AC. I seem to get a constent 2 degrees knock from idle to about 1800 rpm when the AC is on.
Old Oct 6, 2005 | 01:36 PM
1racerdude's Avatar
Did the LT4 come from the factory with Crane gold rockers?
I've never seen a completely stock one.
Old Oct 6, 2005 | 02:47 PM
I get knock retard with the ac on or off. And today on the way to school I wasn't getting any kr at all, then all the sudden I start getting a couple degrees cruising and up to 13.0 degrees whenever i touched the gas pedal. And I don't hear any detonation at all.
Old Oct 6, 2005 | 03:01 PM
http://www.grandsportregistry.com/lt1vslt4.htm
Old Oct 6, 2005 | 05:32 PM
1racerdude's Avatar
Good to know.
Never had a LT4 KM take away the retard on any I have tried it on.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
drt
Sep 27, 2015 04:39 PM
ChrisFrez
Sep 9, 2015 06:52 AM
4586
Aug 22, 2015 01:09 AM
