crank/ hub problem
Old Apr 19, 2003 | 01:50 PM
Max 93's Avatar
crank/ hub problem
Has anyone had a problem getting the hub to go on to a Scat crank? it seems as though the crank is too big for the hub. I have tried an aftermarket and factory hub. Any ideas on how to get this thing on there?
Old Apr 19, 2003 | 02:12 PM
SDAKOVIC's Avatar
first i would use a caliper and measure both. that might give you the answer your looking for. also measure old crank if you still have it.
Old Apr 20, 2003 | 10:36 AM
Max 93's Avatar
Old Apr 20, 2003 | 10:48 AM
TonyJ's Avatar
Well, assuming it's the correct size, just tight, I've read that some people heat the hub up in the oven to get it to expand and then it slips on easily. Use oven mits, though...
1996LT1Z28
Apr 14, 2015 07:15 PM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
