Crank Hub of a 96+ work on a 95?
are they the same? They have different part numbers?
Waht about the balancer? are they all interchangable?
And will a crank hub from 4.3 work on a lt1?
Marcin
Marcin
96-97 hubs are shorter because of the reluctor for the CPS (takes up a little space before the crank gear).
Dampers are probably interchangeable as long as you note whether there are any weights in it. The replacement damper is the same part number for 93-97 and pretty sure it will look like the late model one that has the little puller holes in it.
Don't know about the 4.3.
1LEThumper
Jul 14, 2003 12:45 PM
