Crank Hub
Old Jul 5, 2010 | 07:15 AM
JennyOnNos's Avatar
Crank Hub
Hey guys -
I need a new crank hub and was going with the 'keyed' model below.
http://www.thunderracing.com/shop-by...ankshaft-Hubs/
I have a 95 TA with a rebuilt 97 motor in it. My builder said he did not re-install the CPS reluctor when assembling the motor. This means I will still need the 95 hub, correct?
Also, anybody have tips on installing this? I've been told it is a bad idea to use a hammer or run it on with the bolt.
Thanks.
Old Jul 5, 2010 | 08:09 AM
Yes, you need the 95 hub. An install tool can be made from a threaded rod, nuts and washers all from high grade stock. Hub install is discussed frequently around here.
Old Jul 5, 2010 | 09:20 AM
JennyOnNos's Avatar
Thanks, I will start searching!
AviatorDave
Dec 19, 2016 06:35 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 24, 2015 10:47 AM
Catmaigne
Jul 14, 2015 05:17 PM
