What are your AFGS numbers??
Old Jun 27, 2010 | 07:36 AM
aboatguy's Avatar
What numbers AFGS (airflow grams/second ) are you seeing on your datalogs.... and how much of a pressure drop are you seeing between baro and the map readings?
I've been searching for a little while what the normal pressure drop and MAF for modified LT1s are ....
Mike
Old Jun 27, 2010 | 08:28 AM
At what engine load? Your question is not very specific.
Old Jun 27, 2010 | 09:47 AM
aboatguy's Avatar
I'm sorry WOT at high rpm....
please post
Please post
engine size and mods
RPM
AFGS
Baro
Map
Intake air temp
Old Jun 30, 2010 | 07:08 PM
aboatguy's Avatar
Here's one of mine ....what do you have????
Air Temperature:75degrees F
Barometric Pressure:29.78inches Hg
Relative Humidty:79 %
Density Altitude: 1517 feet
Relative Density: 95.64 %
Old Jun 30, 2010 | 07:25 PM
MikeGyver's Avatar
Barometric pressure here is about 85kpa. My car was peaking around 185gm/sec when stock. Now it's doing 295+ N/A, which would be around 350gm/sec @ sea level.
Old Jul 1, 2010 | 07:31 PM
aboatguy's Avatar
Thanks for the info.....
Here's another log a 371.20
Temperature: 69.1 degrees F
Barometric Pressure:30.01 inches Hg
Relative Humidty:90%
Density Altitude: 858 feet
Relative Density: 97.51 %
Old Jul 3, 2010 | 07:49 AM
aboatguy's Avatar
How about some datalogs folks
Here's a shot from this morning...
Hit 352.4 a couple time on this logging session...
Weather data
Air Temperature: 79 degrees F
Barometric Pressure: 30.03inches Hg
Relative Humidty:82%
Density Altitude: 1539 feet
Relative Density: 95.57 %
Old Jul 5, 2010 | 10:13 AM
NJ-LE's Avatar
aboatguy:
345 gms/sec @ 5250 rpm and ~ +4 psig
167°F water temp + 84°F IAT
74% inj duty cycle
mods as in signature
BTW, what is the mass air flow of a factory stock Z28 LT1?
Boss002
Jan 20, 2016 12:17 PM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
Catmaigne
Jul 14, 2015 05:17 PM
gelbza
Jul 12, 2015 08:10 AM
