crank hub
Old Jul 2, 2006 | 11:41 PM
teekettle's Avatar
crank hub
took my balancer off and found that the bolt that holds the hub on was not threaded on at all. it was just in there,if the hub got off tdc would that make the car miss all the time or just sometime. car has been acting up when it warms up.
Old Jul 2, 2006 | 11:44 PM
Grease's Avatar
Re: crank hub
If its and LT1 then the position of the crank hub does not affect timing. It gets its TDC signal from the optispark which is driven by the camshaft. OBD2 cars have crank sensors.
AviatorDave
Dec 19, 2016 06:35 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 24, 2015 10:47 AM
Catmaigne
Jul 14, 2015 05:17 PM
