Best way to remove LT1 exhaust manifold studs?
Old Jul 2, 2006 | 07:08 PM
fesgali's Avatar
I need to put new set of studs on because 2 broke when putting the ypipe back on.
Whats the best/easiest way of removing them?
Old Jul 2, 2006 | 10:50 PM
1racerdude's Avatar
Re: Best way to remove LT1 exhaust manifold studs?
Take them to a shop that has carbide bits to drill them out and retap the holes.
They are now harder than Chinese arithmetic after all the heat cycles.
Old Jul 3, 2006 | 01:12 AM
Blue96z28's Avatar
yea it sux ***, I did the same with mine, if you take your time, and with the right size drill(physically bulky I mean) they can be drilled out easy from the bottom, wasn't too bad, good luck!
DirtyDaveW
Dec 1, 2016 05:37 PM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
spearous
Jan 12, 2015 11:03 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
