crank, crank, crank, no start
hey all,
my dad's lt1 will crank and crank and crank, continuously. sometimes it gargles but won't start. my dad can crank his car for almost 10 mins straight. sometimes it ill start but die almost immediately.
my dad has tested the fuel injectors and they are all working fine.
both he and i are at a loss as to where to go.
can anyone help us out? with somewhere to look, or whatever?
any help will be much appreciated !!
thanks
Kyle
thanks
Kyle
Could be a ton of things. First two that come to my mind are the optispark and fuel pump. You could see if the car will start using starting fluid, and by checking the FP with the key in the run position. That would give you a decent baseline to get started with. Good luck.
Originally posted by atljar
Could be a ton of things. First two that come to my mind are the optispark and fuel pump. ...
Good luck.
hey thanks guys
i was just out checking things, i turned the car on and primed the car, checked to see if there was fuel at the schrader valve and there is, i don't know what the pressure is since i don;t have a guage that hooks up to the schrader valve
but there is fuel there.
i'm not very familiar with the opti-spark system at all so i have no idea where to go with that, although looking at changing the plug wires does not look like a walk in the park.
how likely is it for the timing chain to be broken? wouldn't it make a noise since there is a lose chain in the cover? i just don't think this is the problem but thanks for the heads up regardless
thanks again, hope the little info helps ....
Kyle
but there is fuel there.i'm not very familiar with the opti-spark system at all so i have no idea where to go with that, although looking at changing the plug wires does not look like a walk in the park.
Kyle
Before tearing into the opti, look into more basic things like the COIL AND COIL COIL WIRE. Make sure that you are getting a signal to the coil, and make sure that the coil wire registers little or no resistance with an ohmmeter. I changed out my coil, and mine wouldn't start unless I pressed on the throttle a little bit. Turned out that the coil wire was bad. A good rule of thumb is to start with the most basic components and work you way up. Same goes for cost. The most basic components are the cheapest, and the more complicated they get, the more expensive they are.
Originally posted by DracoZK
...i was just out checking things, i turned the car on and primed the car, checked to see if there was fuel at the schrader valve and there is, i don't know what the pressure is since i don;t have a guage that hooks up to the schrader valve
but there is fuel there....
Good Luck again.
Alex Barnes
Jan 24, 2015 10:21 PM
1LEThumper
Jul 14, 2003 12:45 PM
