Crane HI 6R install problem with in. PLS HELP with the white wire.
Ok the white wire says points trigger goes to OE electronicignition module. Thats the dew module there talking about right? I mean the module thing behind the coil. If so am i suppose to splice the white wire into one of the dew module wires?
. If somone could explain or give me a write up on where the hell the white wire from BOX is suppose to go it would be a great help.
Called crane they say I need part # 6000-6708 some special connector.
. If somone could explain or give me a write up on where the hell the white wire from BOX is suppose to go it would be a great help.Called crane they say I need part # 6000-6708 some special connector.
