crane 227 or lpe 219/219
Old Jan 20, 2008 | 11:30 PM
Ironxcross's Avatar
which is better? car is a daily driver 90% of the time, but i want something that gives me a nice powerband to play with.
Old Jan 21, 2008 | 11:56 AM
IDAREU's Avatar
I don't know much about the LPE cam but I have had the crane 227. I daily drove that cam for a year with not problems. I wouldnt hesitate to put it in another car.
Old Jan 21, 2008 | 01:50 PM
slomarao's Avatar
i dont know which is better because its hard to say. But it if were me i would go crane 227. There have been lots of good results with that cam.
Old Jan 21, 2008 | 06:48 PM
Don 97 SS's Avatar
I had that Crane cam for about 40k miles and was very impressed with the results. Its a great cam for a driver.
Old Jan 21, 2008 | 07:09 PM
Ironxcross's Avatar
any track times?
Old Jan 21, 2008 | 07:54 PM
ABA383's Avatar
The 219/219 was designed for use with the Superram originally, but should work well...I would suggest the 211/219 which is what I used for 10 years before going to a custom grind...The 211/219 is .533/.560" on a 112 and is very nice with a slight chop and great idle and works great to 6000 rpm...
--Alan
Old Jan 21, 2008 | 10:11 PM
Ironxcross's Avatar
--Alan
i didnt know the lift was that high on that cam, thats nice. it seems like a nice blend of everything, with a little more intake lift than say the crane 227.
Old Jan 21, 2008 | 10:32 PM
slomarao's Avatar
lift is good for hp but its not everything. Duration, lsa, etc. play a lot more.
Old Jan 21, 2008 | 11:02 PM
Ironxcross's Avatar
so the crane 227 with the bigger exhaust duration might be better in that regard?
Old Jan 22, 2008 | 09:26 AM
BUBBA's Avatar
I would think that a little longer duration on the exhaust side would beneficial especially with stock heads.
Old Jan 22, 2008 | 10:10 AM
97WS6Pilot's Avatar
I just went from a CC503 to a CC304. It has a very thick powerband from 1200 all the way to 6000. There is no lope to the idle and it idles with 15" of vacuum. No more cam surge between 1700 and 2200 at light throttle.
Old Jan 22, 2008 | 02:11 PM
93Blackrose's Avatar
I went from the GM LT4 Hot Cam to the LPE 211/219. The LPE 211/219 is a great daily driver cam. In my car, the LPE has more low end grunt than the Hot Cam did. Also, the power is smoother from 1200-6000rpm. The Hot Cam was flat until about 3000rpm then pulled hard to 6000.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
bunker
Aug 21, 2015 10:21 AM
detroit1994z28
May 14, 2015 12:09 AM
