crane 10308 kit
Old Jan 12, 2007 | 07:01 PM
97 LT1formula's Avatar
crane 10308 kit
Is there any machining that needs to be done to run these springs?
Old Jan 12, 2007 | 07:34 PM
Greaseymec's Avatar
Nope. They drop right in. Mine are doing fine.
Mec
Old Jan 12, 2007 | 08:27 PM
ok sweet, thanks.
Old Jan 13, 2007 | 08:54 AM
NightTrain66's Avatar
yep, these work fine with no machine work and can handle a pretty big cam.
I now use these on my LE1 heads instead of the CM 612 springs.
Some thick alu rockers sometimes have problems with the large diameter retainer but Comp Pro mags work fine.
Old Jan 13, 2007 | 09:06 AM
mattbailey's Avatar
Got those on my car, nice price and no problems.
Old Jan 13, 2007 | 12:06 PM
Bersaglieri's Avatar
Great spring kit. Priced very well considering what they can handle. Cant beat keys, shims, retainers, and good dual coil springs for $150.
-Dustin-
Old Mar 4, 2007 | 07:05 PM
69z-28's Avatar
ill be running a 503 cam with 1.6 3/8 SA pro mag rockers, this crane kit and stock heads.....
with these shims, do you drop them in and then install the springs, retainers and locks or do you need to measure to see what size shims you need. is it basically a "bolt in" kit or will i have to figure out how much shimming needs to be done depending on each cylinder. i know my dad always takes his heads in to the machine shop and gets the springs matched with the cam along with the retainers, locks and gets them shimmed properly, but i wasnt sure if i could throw the kit on w/e any problems are calculating.
Old Mar 6, 2007 | 12:34 PM
69z-28's Avatar
bump
Old Mar 7, 2007 | 10:48 AM
Z-RATED94's Avatar
Your right, different shims might be needed. That's why you have to measure the installed height.
Old Mar 7, 2007 | 11:18 AM
69z-28's Avatar
with the hotcam kit, is there one shim that you use and it all fits perfect or what? ill be doing a cam, spring, retainer, lock and shim swap in my garage so i wont exactly be able to start measuring tolerances with my valve covers off under the hood of my car. got any options that suit my needs?lol thanks
Old Jul 2, 2008 | 10:17 AM
GMH94Z28's Avatar
I am in the same boat right now. What did you ever do?
Old Nov 17, 2008 | 10:12 AM
ss.slp.ls1's Avatar
So what does the installed height have to be? Does the Crane kit (1308) come with shims?
Old Nov 17, 2008 | 11:02 AM
camarobird92's Avatar
There is a tool that measures installed height of springs. You have to find out your installed height. Then based on what your spring preasure needs to be, you use different shims.
Old Nov 17, 2008 | 12:35 PM
Stl94LT1's Avatar
Valve spring micrometer.
Old Nov 17, 2008 | 01:10 PM
Yah!!! That's the tool!!!!
