cracked block
Old Oct 26, 2014 | 09:56 PM
Albone's Avatar
cracked block
Has anyone had their block crack in the same place? Got any ideas on what could cause this?
It was a 383 with eagle crank, stock rods, and speed pro pistons. I bought it that way and it only lasted about 6 months before it started knocking. I finally got around to taking a look and i found this (among other things), which I think was the source of the knock.
Old Oct 27, 2014 | 09:59 AM
Albone's Avatar
Re: cracked block
here is the thread i made years ago when I first heard the sound. I lost interest for a while but found the motivation again and plan to get the car up and running for next summer.
https://www.camaroz28.com/forums/lt1...-think-638857/
Old Oct 27, 2014 | 11:53 AM
Chimera96's Avatar
Re: cracked block
could have been several reasons the block cracked there in the rear
bad line bore for crank
running external balanced FW/Flexplate when engine was "internal" balanced (if it was)
eagle cast crank
that block is scrap, start over with better "forged" parts...and build
Old Oct 27, 2014 | 07:35 PM
Albone's Avatar
Re: cracked block
i already got another block. the crank was not damaged at all, all journals mic like new. i wish i knew what the previous owner did as far as balancing goes. i dont think forged is necessary for my purposes though.
Old Oct 27, 2014 | 10:04 PM
Chimera96's Avatar
Re: cracked block
if your Eagle crank is forged, it is "OK". Their cast stuff, no.
have a qualified shop prep the new block and balance rotating assembly "internal" balance aka neutral. You will need to run a neutral balance FW/Flexplate.
who knows wtf PO builder did but something FUp'ed
Old Oct 31, 2014 | 09:52 PM
MachinistOne's Avatar
Re: cracked block
Originally Posted by cardo0
Wow, have never seen a block break there before. Thx for following up and sharing.
Yeah, that's a new one for me too - somebody did something stupid.
RUENUF
Mar 13, 2016 03:39 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Noct
Jul 14, 2015 01:18 AM
colts0455
Jul 8, 2015 12:21 AM
camaro02DK
Jul 5, 2015 09:04 AM
