Couple quick questions, need help ASAP, PLEASE!
Old Jan 11, 2004 | 02:23 AM
Blue96z28's Avatar
Question Couple quick questions, need help ASAP, PLEASE!
I'am right in the middle of a opti/elec water pump install and i need some info on a couple things....everything went together well so far, i have the new opti and waterpump w/csi installed.....but how does the balancer go back on?
I'am used to the older small blocks that have a grove for the woodruff keys and they only go on one way. But what about these, can they be installed in any postion, or are they balanced for only one position if so, how do i line it up perfectly without all the crank key groove? By balancer is flat inside and doesnt have any goove? WTF is going on here?
Also I changed all the seals on the timing cover while i was at it, and i know the crank seal should be greased and the opti seal said to leave it dry so i did, but what about the waterpump seal? it looks like its teflon as well......so i installed it dry, should i have greased the lips of it like the crank seals are supposed to be.....
any help would be great, as my car is not running, and i need it back ASAP.
thanks
Old Jan 11, 2004 | 02:33 AM
sssalah's Avatar
With #1 at TDC the key at the crank (that holds the gear) should point at a 45° angle or at 1:30, you can then put on the hub with the pointer on it facing straight up. Try to look carefuly inside the hub bore and you maybe able to see a marking.
Old Jan 11, 2004 | 02:39 AM
Blue96z28's Avatar
so it has to go on just like it came off is what your telling me though? I really dont want to take plug out and go the hassle of rigging up a light and looking there and what not for TDC calculations, is there an easier way?
Old Jan 11, 2004 | 02:52 AM
sssalah's Avatar
If you don't get it installed right your engine may shake/be out of balance. Its not that difficult to get approximate TDC and thats enough for a hub installation.
You can put a rolled paper tissue at #1 spark plug hole and rotate the engine clockwise until the tissue pops, then you must rotate it a little more until the crank key is at 45°.
Old Jan 11, 2004 | 02:56 AM
Pasky's Avatar
Well, if your pretty experienced, you can do what I did and stick a flat head screw driver in the #1 spark plug hole and rotate the crank until the clyinder barely touches the screw driver, I set my screw driver at an angle so I could pull it out easier and just turn it enough to where the cylinder was at the very top. Be careful not to break the piston or screw driver in there. Don't do it if you don't feel you can, but its not hard at all.
Old Jan 11, 2004 | 09:49 AM
Its a "harmonic damper"... not a "balancer". Exact location is generally not critical. That's why they didn't bother with a key. I've heard stories of some LT1 dampers using the holes around the edge for extra weights, used by the factory for final tweeking of vibrating engines, but I've never actually seen one. Just get it "close". Did you look at the inside of the hub to determine if you could see the "outline" of the crank key slot, you know, not an actual slot, but a discoloration from where the hub sat on the crank slot?
Old Jan 11, 2004 | 09:57 AM
Blue96z28's Avatar
Well so far I've gotten two completely different answers.......i just dont know
Injuneer's point makes sense, if it would have been critical then it would have had a key in it, but there bolt holes drilled all over this thing, on the outside ring, and on the center hub, for balancing i'am assuming, i would just really like to know "how citical" it is, but i guess i'll just slap it on and get as close as possible......Yeah i can see the line inside, plus a slight nick on the end of it, where it was pushed up against the back key just barely, so i'll just go see what happens.....
Old Jan 11, 2004 | 10:09 AM
It's my opinion that the "holes" in the hub and the damper were put there to neutral balance the hub and the damper. Those tiny holes, located so close to the center of rotation of the crank, would not have a significant impact on balance of a "factory" engine. Some people claim they have found "heavy metal" inserts in a few of the holes.
This article indicates:
HUB AND BALANCER
The balancer is a two-piece assembly with a pulley that bolts onto the hub. Separating the two made it easier to install the Optispark distributor on the assembly line and out in the field. The holes in the hub are offset, so the balancer only fits on it one way, but there’s no keyway in the hub to index the hub on the crank. This shouldn’t be a problem unless the damper was drilled at the factory to "trim" the final engine assembly.
If it was drilled a lot to compensate for an engine that was out of balance, you could end up with a shaker, depending on how everything stacked up with the remanufactured engine compared to the original engine. If you encounter a balance problem on a remanufactured LT1, try rotating the balancer assembly on the crank 90° at a time to see if it eliminates the problem.
This book on rebuilding the LT1/LT4 recommends that the damper should be neutral balanced, and that most "out-of-the-box" dampers are neutral balanced.
Old Jan 11, 2004 | 10:17 AM
buelldevil's Avatar
The holes are drilled to ballance the damper it's self. Same as adding weights to your wheel.
Old Jan 11, 2004 | 10:19 AM
If your pulley has any weights in the holes, you might want to get it back as close to what it was. If not, there probably won't be a problem, however it is nice to have the hub oriented properly for determining correct crankshaft position (like when setting valve lash).
Inside the hub, you should be able to see a shadow line from the crank keyway. Transfer that line to the outside of the hub where you can see it as you line it up for install. That should make it pretty close.
Old Jan 11, 2004 | 11:57 AM
BadAssed93Z's Avatar
well i have my block stripped bare and im going to a 383. how can i assemble this and make sure everything is right?
i have 2 weights in my dampner but does that matter if im going to a new crank? should i take those weights out?
threads like this let me know how much i still need to learn.
thanks
Old Jan 12, 2004 | 12:25 AM
Since your engine is apart, I would have the damper balance checked to insure it is neutral. Then, have the hub keyed, or buy a keyed hub. If you are building a serious motor, it may be worthwhile to go to the ATI SFI-rated balancer. SFI rating is required for cars running under 11.00
Old Jan 29, 2004 | 01:05 AM
Blue96z28's Avatar
Sorry for the no response time, I did this basically on the re-install and everything seems good so war, no new "vibration" or anything after the re-install......and mine did have the small weights in some of drilled holes....so who knows?
I replaced the all the cover seals as well.....not a drop....its great.
thanks for the help guys
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
ChrisFrez
Jan 4, 2015 08:43 AM
