couple questions on my engine build..
Old Jul 28, 2009 | 06:32 PM
1993Fast_Z's Avatar
what is the difference between the 92-94 cam and the 95-97 cam?
can i reuse my stock head bolts and washers?
Is the WP drive bearing known to fail? (i have some slight roughness when i turn the WP drive?
Old Jul 28, 2009 | 08:16 PM
The 95-97 cam has a longer dowel pin to drive the Opti, and a larger diameter, deeper hole in the front end to serve as the pilot hole for the vented Opti's pilot shaft.
The stock head bolts are torque-to-yield and should be replaced.
Jan 13, 2015 09:52 PM
ChrisFrez
Jan 4, 2015 08:43 AM
cmdeshon
Dec 27, 2014 10:06 AM
pete53
Dec 9, 2014 07:31 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
