Couple questions about my opti
Old Feb 18, 2007 | 12:00 PM
Tricked-Out-Toy's Avatar
Ok I think my opti is going out but Im not sure. the car was on the dyno about 4 months ago and the graph was really jumpy and the guy said that whenever he has seen a graph like mine the opti was ussually on its way out. so with that said last night I was out for a cruise and started to notice what felt like cam surge around 2500-3000 rpms. If I went wide open no problems. no surge, it just felt normal but below 3k it was surging, this morning I take it out to the gas station and it popping and surging below 3400 stop at the gas station. 5 mins later I start it back up and it seems to run fine with just a hint of surge around 2500. so what do you guys think? sounds like and opti but would you say opti for sure?
Another thing the LTCC is a nice option but every set up ive seen makes the whole engine look really really cluttered! does anyone have any ideas on how to make it look a little cleaner or to hide the coils somewhere? that is the only thing turing me off on the whole conversion.
Oh and I should mention I parked my car next to a 4th gen lt1 SS that was having problems with its mass air flow sensor and wouldn't idle for ****. could my car have "caught" the flu from the other car!? they weren't parked to close but it was cold and I think the 4th gen might have sneezed in my direction!?
Old Feb 18, 2007 | 12:26 PM
FireFox5.0's Avatar
I would check the MAF and Fuel pressures before I would go replacing the opti. If the opti is going out, it will start missing.
Old Feb 18, 2007 | 01:10 PM
fuel pressure is good, no code reader so I cant tell if anything is thrown on the maf.
Old Feb 18, 2007 | 01:51 PM
I don't run the LTCC, but I do run another system with 8 LS1-style coils, and they are mounted at the bottom of the radiator support, completely out of sight.
Old Feb 18, 2007 | 03:48 PM
do you have pics of it? Im starting to lean towaed the coil per cylinder option IF I can keep the coils from making my engine bay cluttered. by mounting the coils to the rad support do/can you route the wires under the header?
Old Feb 18, 2007 | 04:40 PM
salty's Avatar
My opti failed with similar symptoms, but at a lower rpm. Lots of popping and hesitation at full throttle. It was a crusty old opti whose time had come.
Old Feb 18, 2007 | 07:30 PM
OBE1 95Z28's Avatar
I would start by cleaning the MAF. A lot of people over oil their K&N filters and get the MAF "hot wire" dirty. You stated that your fuel pressure is fine; did you check it under load or only at idle?
Old Feb 18, 2007 | 07:34 PM
I checked it driving around under load and under load wide open. I cleaned the maf about 4 months ago and havent cleaned the filters since.
Sergio
Jan 27, 2016 04:27 PM
ChrisFrez
Jan 4, 2015 08:43 AM
Injuneer
Dec 15, 2014 09:36 AM
96z
Aug 2, 2002 09:00 PM
