A couple questions about a cc 503 install.
So far Ive just bought the cc503 cam and gmmp 1.6 3/8 rr, and im about to order a Crane Cam valve spring set on summit.
P/N 10308-1
Will those springs work for my set up? Also what size of push rods should I get? I was thinking of these
COMP Cams 7808-16 size on these is 7.195
Is set up fine or will I need shorter or longer push rods? And are the springs alright too or will I need any extra parts?
Thanks,
P/N 10308-1
Thanks,
those valvesprings SHOULD work great. i had a 224/224 cam with .532/.532 lift with 1.6 rockers and loved how they worked out for me. just make sure you have enough clearance with the cam lift, i forgot how much lift the 503 has.
Ok I am going to be doing the exact same set up...CC503 and I was going to order the Crane dual valve spring kit w/ retainers.
My question is, What spring locators (seats) do I use with these springs?
Anyone happen to have a part # for them along with the valve seals?
I'm ordering parts today, thanks.
Jan 13, 2015 09:52 PM
96z
Aug 2, 2002 09:00 PM
