Couple Questions
Old Mar 15, 2007 | 03:27 PM
87bandit's Avatar
Couple Questions
what's the most you can shave off a stock LT1 casting head with stock
stroke without running into clearancing issues and what thickness
headgasket would you recommend with this?
also when people use a "stock" crank, are you reusing your stocker or buying a new OEM crank? what is done to the crank prior to install to insure it?
squarehead
Jan 15, 2015 07:02 PM
Jan 13, 2015 09:52 PM
ChrisFrez
Jan 4, 2015 08:43 AM
pete53
Dec 9, 2014 07:31 AM
96z
Aug 2, 2002 09:00 PM
