Couple problems need to be taken care of...
Ok, some minor problems i have right now.
The passanger side door won't lock or unlock using the remote or the buttons inside the car, i have to reach over everytime to lock/unlock it, the drivers side works fine. Do you think this is a switch, blown fuse, frozen lock (just before it fully stopped working, it was on a freezing cold day and it started to lag a little before it went out)? I was thinking i might try opening up the door panel and using some WD-40, which im not even sure where would be the best place to spray it on...
Next is, the drivers door window keeps stopping on the way up, so i have to wait like 10 seconds to put it down a little bit then back up to get it to reach the top... I'm pretty sure this is the motor, if so i found motors on ebay for 40 bucks new.. would you recommend buying these and putting them on myself? Would this actually speed up the slow a$$ windows that most fbody's have? lol
I need to change my tranny fluid and i want to change my rearend fluid.. would you reccomend getting this done by a dealership or just do it at home. I read that i can cause problems to get a flush on tranny's w/ high miles on them. My car is a 97 TA w/ 80,000 on it. If you reccomend doing this at home, whats the best way to drain most/all of the fluid from the tranny?
Thats about it... cept for the low rpm hesitation which seems to be wayyyy too popular w/ lt1's. I think GM should make a recall about that problem, its just an annoyance. I have msd 8.5mm wires, ngk tr55 spark plugs, changed fuel filter, did recent oil change w/ coastal half synthetic, 170 degree thermostat from autozone cuz the car was overheating, took out the Airfoil that was kinda loose and came w/ the car when i bought it, cleaned K&N filter, Cleaned MAF, tested EGR valve which chocked the engine when i pressed it in (im guessing this means its working), i changed a bad 02 sensor with a boche one from autozone (that gave me a code). Thats all i can think of right now that i have done all WITHING THE LAST 1000miles or so... I wish there was a simple fix for this like the headlight motor fix
Thanx in advanced for any feedback.
Magenta_Hearts
Mar 25, 2015 10:24 AM
