Couple of minor questions
Old Oct 2, 2005 | 07:52 PM
MyShibbyZ28's Avatar
valvetrain and cam questions
First, I can't find anywhere that says you need to use an LT1 specific camshaft. Can you use any SBC camshaft or does it have to be made for an LT1?
Second, I feel like my engine is going to go soon. It has 181,000 miles and has not been rebuild. I'd like to go with the CC306 camshaft when I do rebuild, so would I have to change the lifters, crank, pistons or anything? I know I'll have to change the valve springs and such. But what exactly should be done when changing to a CC306?
Third, what degree seats/locks or what ever should I get for the springs? As you probably noticed I'm not experienced with the valvetrain or anything.
And lastly, are LT1's 1 piece rear main seals or 2 piece?
Any help would be appreciated.
Old Oct 3, 2005 | 12:30 AM
coolraptor's Avatar
Re: Couple of minor questions
Check this out
http://web.camaross.com/forums/showthread.php?t=400477
With that many miles i would save the money for it and put a new bottom end in it too unless its still in good shape once its torn down but i'd atleast re-ring and all that good stuff.
Iam pretty sure lt1's are one peice rear seal.
Thats all i know/think i know
Hope it helps some...
Old Oct 3, 2005 | 12:59 AM
rskrause's Avatar
Moderator
http://static.summitracing.com/globa...hpb-hp1393.jpg
It has a 1pc. rear main.
Rich
Old Oct 3, 2005 | 07:50 AM
I don't know what any of the bottom end looks like so i won't know it's condition until i need to rebuild it. Would having it bored to 355 be a good idea too? or should it just need to be re-ringed and sealed? what about getting forged pistons? When i rebuild it i'd like to get it all done in one shot.
Old Oct 3, 2005 | 08:49 PM
What about using any SBC cam in an LT1, or does it need to be LT1 specific.
Old Oct 3, 2005 | 08:55 PM
rskrause's Avatar
Moderator
Different nose on an LT1 cam.
Rich
Old Oct 3, 2005 | 09:23 PM
Rich
Technically that doesn't answer my question. But I'll assume that means you need an LT1 specific cam.
Old Oct 4, 2005 | 12:44 AM
SStrokerAce's Avatar
Actually it does answer your question.... you need to have a stepped nose for the cam retention plate AND a hole in the nose for a Opti, meaning YES THE CAM IS SPECIFIC TO THE LT1..... not to mention the dowel pin length.
Bret
Old Oct 4, 2005 | 04:21 AM
rskrause's Avatar
Moderator
Bret
I thought so too? I suggest the book I posted a link to. It has good general rebuild information as well as answering a lot of the specific questions you have and many you haven't even thought of!
Rich
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Sandersen511
Jan 13, 2015 03:49 PM
ChrisFrez
Jan 4, 2015 08:43 AM
Queens94z28
Dec 20, 2014 09:11 PM
