Couple of LT1 Questions
I just had a 355 with ported and polished heads and LT4 hot cam kit. What injectors do you guys recommend I run on this motor? Brand, supplier, and pressure?
I am putting LS1 front brakes on the car too. I have the spindles and calipers. What brake lines should I run? LS1 or LT1?
Any constructive comments would be greatly appreciated.
30# SVO's will be plenty. Stock 24lbs are good up to 400 rear wheel though as long as in good working condition. If you have a lot of miles on them go ahead and upgrade to 30lbs. You will need a reprogram for them.
Jon
Jon
Jan 13, 2015 09:52 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
