Couple LT1 problems need help
Old Aug 10, 2007 | 08:19 PM
wonbadassz28's Avatar
I have a 96 LT1 with the six speed and i have just under 120,000 miles on it, now on to my problems:
1. Had a crack in my radiator and replaced it, since then if i drive it and get it up to temp and shut it off and then start it before it cools down it will peg the temp gauge and then the coolant backs up and boils out through the overflow. So far ive replaced the rad, both temp sensors, confirmed the fans are working, new GM rad cap, new thermostat, and bled out the air. Any ideas on what could be causing this?
2. Occassionally after i start the car my ABS INOP light and my traction control light will come on and stay on. Any ideas on what this could be?
3. Sometimes when i try to start it the security light will come on and not allow me to try to start it again until the light goes off, sometimes it only does it once, sometimes more, it hasnt done this lately but i would like to fix it. Any ideas on what this could be?
thanks for the help in advance
Old Aug 11, 2007 | 12:22 PM
Generally better to make a separate post for each problem. Not as likely to get answers when you lump them all in one post.
1. What bleeding procedure are you using? What blend of coolant/water are you running?
2. Which "traction control light" comes on?
3. Could be related to the security pellet in the key. Is the key corroded? Are the contacts for the pellet in the ignition switch corroded?
Old Aug 11, 2007 | 12:48 PM
yeah i am starting to think i should have seperated them
1. to bleed it i was filling the rad with the bleeder closest to the thermostat open and continued to fill the rad until it was just up to the bottom of the neck and there was a steady stream of coolant coming from the bleeder and no bubbles or air
2. Its the ASR OFF light or whatever it says, the one that comes on when the turn the traction control off
3. The key and contacts both appear to be clean, i guess getting a new key cut could help that
Old Aug 11, 2007 | 12:49 PM
oh sorry, im using 50/50 prestone the kind that says it can be mixed with any color system
thanks man
Firebird_fr3ak's Avatar
Your coolant problems sonds like what happened to me in my bird, ther was an air bubble in the t-stat housing that kept it from working right. i just bled it out and got a new t-stat.
Old Aug 11, 2007 | 12:53 PM
how exactly were you bleeding yours?
im hoping im just not bleeding it right, i dont think its a head gasket cuz theres no smoke and the oil looks normal, but who knows, maybe a water pump?
Old Aug 11, 2007 | 12:56 PM
Well on my v6 there was only one bleeder on the housing, i did what you did...sorry. Did you bleed the other side too?
Old Aug 11, 2007 | 01:00 PM
yeah, but the other one appears to be on a heater hose and is rather high, i only got a little from that one, i searched for an exact step by step on how to bleed these things and can't find it, everything tells you how important it is to bleed these things out completely but nowhere tells you how to accomplish this
Old Aug 12, 2007 | 11:29 AM
If you're not familiar with Shoebox's LT1 Tech Page, you might want to bookmark if for future reference.
http://shbox.com/1/4th_gen_tech2.html#radflush
http://shbox.com/1/4th_gen_tech1.html
Old Aug 12, 2007 | 12:45 PM
cool thanks a lot man, never read those before
Old Aug 24, 2007 | 05:36 PM
ok guys, finally got this thing fixed after the new rad, new temp sensors, new rad cap, new thermostat, new overflow tank cap and hose, i still couldnt get this thing to stop boiling over so i took to a shop and within two hours of dropping it off they had it fixed, i had somehow got the bypass hose and the overflow hose switched on the rad., i felt like a total retard, but whatever now its fixed and i would have never ever checked that
thanks for all the help guys
-russ
DirtyDaveW
Dec 1, 2016 05:37 PM
jb4xx
Feb 2, 2015 10:00 PM
squarehead
Jan 15, 2015 07:02 PM
slothgrant
Aug 22, 2002 03:01 PM
