could this be a spun bearing?
Old Sep 30, 2003 | 01:33 PM
  #16
InjectedSS's Avatar
Well you DEFINATELY have both. When your car is idling, that tick is your header leak, and when you rev it that is definately rod knock.
This is EXACTLY what I was trying to show ollie-99 the other day when he had me listen to his video. If you guy's listen to his video he posted you can see that his video was CLEARLY a bent pushrod like I said.
This video here is definately header leak, and rod knock. Time for a stroker
Old Sep 30, 2003 | 03:32 PM
  #17
marshall93z's Avatar
if that noise you hear is a header leak then it stawhen the rod started knocking. it wasnt doing it before the bearing problems.
Old Sep 30, 2003 | 04:20 PM
  #18
InjectedSS's Avatar
Well either way dude you have BOTH. Maybe you just never noticed the header leak before.
Old Oct 1, 2003 | 10:47 AM
  #19
thanks for the replies guys.
that sux because i have only put about 600 miles on the car since i bought it. never even had it to redline
oh well, guess i know what to do now...
Old Oct 1, 2003 | 11:06 AM
  #20
grygst76's Avatar
Mine sounded just like that when I had a bent pushrod here is another trick to find wbich one it is and it works
unplug a spark wire to one cylinder and turn it over.
Listen while it runs
go to the next cylinder but first plug the one you just did back in.
you will quickly find the bad cylinder and then you can determine from the top bent pushrod or bad rocker arm and bad exhaust leak, Try it and tell us what cylinder it was.
Old Oct 1, 2003 | 01:10 PM
  #21
ive had the vlave cover off and its not in the top end.
Old Oct 1, 2003 | 04:28 PM
  #22
schpenxel's Avatar
Can u get the oil pan off??..I havent been under a LT1 in a while, so im not sure how hard it is...but there will be no doubt after u do that.
Carson
Old Oct 1, 2003 | 04:57 PM
  #23
GreenZ28in503's Avatar
Like some others, I'd pull the filter and cut it in half, see what you find in there before you go tearing your engine apart. It's hard to tell what that noise is from the video. Could be a lifter that collapsed or turned in the bore, a broken ring, a rod/main bearing etc.
I'd be a little suspicious of calling it a bottom end problem right off the bat since your oil pressure stays pretty good and it goes away when the engine is warm.
Old Oct 1, 2003 | 05:51 PM
  #24
RCF925's Avatar
GreenZ28in503 , What he said , That doesn't sound like a rod or main bearing to me. You do have an exhaust leak or sticky lifter, Maybe a collapsed lifter. I would do the oil filter check and drain your oil before I went tearing through the bottom end.
Old Oct 1, 2003 | 06:10 PM
  #25
Seabat's Avatar
Ouch
Sounds ugly alright, besides the exhaust leak, perhaps a bad rod bearing or busted piston. With the engine warmed up and turned off try turning the engine over a little in both directions ( put a socket on the crank hub bolt ) in other words rock it back and forth. Sometimes you can feel the slack in a rod bearing.
93 Red M6 60K
Off road pipe, EGR, TBB, B&M Shifter
Old Oct 1, 2003 | 10:25 PM
  #26
i dont think its in the top end cause everything is tight.
im gonna check the filter tomorrow and see what the deal is with that.
Old Oct 2, 2003 | 03:48 PM
  #27
DJ_951's Avatar
Mine is quite till the engine gets warm, and the oil pressure drops. Still good oil pressure at temp. Replaced the two lifters that seemed to be were the noise was from. Still making the noise. Going to try the springs next. Anyone have idea's. No metal in oil.
Old Oct 3, 2003 | 10:50 AM
  #28
i took the filter off and poured some oil out of it and it looks like paint with some very fine metal flake in it.
Old Oct 3, 2003 | 11:27 AM
  #29
grygst76's Avatar
cut the filter and check for bigger chunks caught in it, if you have a digital post it and someone will know what it is..
Old Oct 3, 2003 | 11:44 AM
  #30
S.J.S.'s Avatar
Well....like I said, hate to tell ya but mine sounded exactly like that and if you got the flakes then its pretty obvious.
Sorry
