could a O2 sensor make a car run bad?
Old Feb 2, 2006 | 08:50 PM
94 guy's Avatar
my car runs really rough from idle on.
Old Feb 2, 2006 | 08:55 PM
Hawk's Avatar
Re: could a O2 sensor make a car run bad?
yes it can, first hand experiance here.
I had a problem with interference on the o2 signal wire, I had tapped in that for an A/F guage and it was causing problems such as stumbling and backfiring. Once I fixed that it was better.
Most of the time though, if an o2 sensor is bad it will throw a code. Sometimes, it won't.
Brian
Old Feb 2, 2006 | 08:59 PM
J's 82's Avatar
Agree with above.. I diagnosed a firebird that was running awfully, bucking, smelling, etc.. hooked it up to my laptop and it showed one O2 stuck at a high reading, no trouble codes. After the O2 was replaced it ran like a new car..
Old Feb 2, 2006 | 09:06 PM
Jameslt1TA's Avatar
My o2 sensors are causing me to have split blms and making the car run very rich.
But on yours, the o2s moniter the air/fuel ratio when the car has warmed up and is runnin in closed loop. If one isnt working right, it wont give the comp the correct a/f ratio and it will run terrible.
Good luck
James
Old Feb 2, 2006 | 09:26 PM
Brettinator's Avatar
absolutely can make it run bad, I also had a bait of issues with the drivers side 02, Denso (think it's called) makes a nice 02 compared to Bosch (went through 4 sets) couple years back. Autozone will scan for free and tell you the code.
Old Feb 2, 2006 | 09:28 PM
94 guy's Avatar
don't buy bosch?
Old Feb 2, 2006 | 09:34 PM
Jameslt1TA's Avatar
Originally Posted by 94 guy
don't buy bosch?
Buy the stock gm replacments...i have also heard bad things about bosch.
Old Feb 2, 2006 | 11:55 PM
matt65's Avatar
Yes it can.
Queens94z28
Dec 20, 2014 09:11 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
