roller rockers and valve spring help!!!!!!
Old Feb 1, 2006 | 08:49 PM
Roach02's Avatar
Okay my 95'Z is stock except for a few bolt-ons. How much hp increase can i see with diff. roller rockers and valve springs? and what do you all recommend when it comes to this!! Help me out here guys.
Old Feb 1, 2006 | 09:01 PM
truedualws6's Avatar
Re: roller rockers and valve spring help!!!!!!
10-15 rwhp is the norm with 1.6 rockers.
Parts depends on your budget and future plans. If you are not going
to do anything else and want to go low budget then consider the
LT4 springs and Comp magnum 1.6 rockers. You should also replace
the valve stem oil seals while you are in there. The for sale board is
also a good source for parts.
Old Feb 2, 2006 | 01:43 PM
Roach02's Avatar
so are these what you suggest i get then? http://store.summitracing.com/defaul...earchType=Make
and where can i get the LT4 springs?
Old Feb 2, 2006 | 05:03 PM
The LT4 spring set is less than $40 list price from the dealer. I have
a connection a my local dealer and got them for $32.
GM PN 12495494
I think the number for the rockers is Comp 1418-16, but you need to
confirm it.
Old Feb 2, 2006 | 06:18 PM
Roach02's Avatar
Well i'll go to my local dealer tomorrow and check on the price for the springs. I used to work there and still get employee list price so hopefully that'll save me too like you lucked out with. I searched Comp Cams website for that part number and came up with this. http://www.powerandperformancenews.c...Category_Code= This is correct right. If you can't tell i'm clueless really about all this stuff lol
What sucks is i just got a tune from madz28.com and if i do this i'll have to send it off for a retune!
Old Feb 2, 2006 | 08:06 PM
1racerdude's Avatar
Get the retainer's and keepers with the springs. I didn't and it cost me an engine. The stock retainer folded up from the increase in spring pressure and dropped a valve @ 6000.
Old Feb 2, 2006 | 10:48 PM
bowtiethunder's Avatar
1418-16 are roller tip rockers. 1318-16 are full roller rockers
You can get them alot cheaper elsewhere, I had Summit to price match mine for $278.
Old Feb 3, 2006 | 12:10 AM
Compstall's Avatar
We could bench race power numbers all day, but I gained 7 hp at the wheels and 2 lbs. of torque on the dyno.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
