Could a gear change cause this?
Old Oct 15, 2003 | 11:23 PM
crzhrs's Avatar
Question Could a gear change cause this?
I have a 94 z-28 A4 when I get to about 5200 RPM's my car don't seem to have any power left. But, it don't shift until 5800. Could this be caused by changing the gears from 2:73 to 3:23? Does a gear change throw off the shift points? Please Help!
Old Oct 15, 2003 | 11:36 PM
aintno6's Avatar
did you get it programmed yet? Because if you dont, your shiftpoints will be all jacked up, and so will ur speedo.
I went to from 2.73 - 3.73. and I just had a shop program just the 3.73's . And when I went to the track I still hit limiter right before 3rd. So they need to be re programmed.
Old Oct 16, 2003 | 09:10 AM
RallyRed701/2's Avatar
yeah i went from 3.23 to 3.73 and my shift points are still are jacked up... awaiting pcmforless programming... hell it better be here today!
Old Oct 16, 2003 | 09:16 AM
snake_skinner93's Avatar
i went from factory 3.23 to 3.73 gear change, and my shift points were normal...speedo was all messed up but the car shifted fine...even under WOT
Old Oct 16, 2003 | 06:39 PM
crzhrs's Avatar
That would have been my next question. Can you change shift points? I use to try to shift the car around 5200 RPM's when racing but it keeps climbing up to 5800. Past the point where is has power.
PCLZ28
Dec 24, 2015 05:19 PM
David Dorris
Jan 17, 2015 08:10 PM
Jul 4, 2005 05:00 PM
