Could this be caused from a optispark?????
Old Jun 9, 2004 | 05:25 AM
detroit1994z28's Avatar
I have a 94 camaro z28. When my car gets hot my car seems to be missing like - it tends to struggle to build up rpms like it's missing. Could my opti spark be going. Are those signs. How can I check to see if my optispark is bad
Old Jun 9, 2004 | 07:22 AM
GRndPNdN93Z's Avatar
i just replaced my Optispark and my car was missin, studdering, loss of power. it would idle OK but as soon as u gave it any fuel it would miss, pop, and backfire like there was no tomorro.
Old Jun 9, 2004 | 08:00 AM
transamtom's Avatar
Re: Could this be caused from a optispark?????
Sounds like the ignition module,its located above the coil on the front of the drivers side cylinder head
Old Jun 9, 2004 | 12:59 PM
re:
My car is doing the same thing it idles great but when I actually get into the car has no performance. When I had my cam installed the lt4 hot cam. The guy had installed a USED opti spark he bought it for $150.00. I guess he said my old one was bad which I had that replaced last summer which also was a used one. I'm guessing it's the opti. THE dealership should tell me right???
Old Jun 9, 2004 | 02:14 PM
Deenasty's Avatar
Re: Re: Could this be caused from a optispark?????
ditto...usually when heat makes it worse, its the ICM... Also when you replace it..use some washers to space it away from the head to keep the ICM cooler...
Old Jun 9, 2004 | 02:44 PM
bdc95ta's Avatar
I don't think that's right. I've heard and read that when the ICM goes out it just goes out. Without warning, it's either your car starts =it works or car won't start=ICM could be to blame.
Old Jun 9, 2004 | 02:47 PM
bdc95ta's Avatar
oh and personaly I would NEVER buy a used opti. for my car. You could of spent $60 more and got one from Jason Cromer.
Things I would check:
-plugs and wires look for fireworks at night
-fuel under load also
-check warning lights if u have um probably don't though I didn't
anyways
-vacuum leaks
-check your cat
I guess someone else can chime in with more. Or do a search the wealth of knowledge on this website for are cars is amazing.
Old Jun 9, 2004 | 02:50 PM
jd94z28's Avatar
Not for a 94 as his name implies. The nonvented optis are around 300.
Old Jun 9, 2004 | 02:54 PM
bdc95ta's Avatar
oh your right my bad jd.
Formula Steve
Sep 19, 2023 08:31 AM
KYWes
Jun 14, 2022 06:52 AM
Double aught
Oct 2, 2015 11:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
jackpawt883
Sep 10, 2015 08:53 PM
