Cough/pop-back in 4th. gear?
Old Sep 22, 2008 | 11:39 PM
LJM97Z's Avatar
I posted over in the ignition section, but maybe i'll get more responces here, whats happening is at the track in 4th. gear ONLY (M6) at around 5000 rpm it coughed/popped back, it only does it once & only in 4th. gear, i'm sure its because its under the hardest load in 4th. (engine does feel alittle shacky in 4th. WOT), i was told it could be the ignition control module vs. Opti, it starts fine & runs fairly good otherwise under normal/moderate conditions, i'm hopeing its not the Opti, i haven't check if its throwing any codes, the SES light has been on ever sence i installed the LTs & Ory & eliminated the rear O2s. awhile back, how would you check the Ignition module? Has anyone exsperienced this before?
Old Sep 23, 2008 | 12:10 AM
87bandit's Avatar
high rpm miss could be alot of things
plugs, wires, opti, coil, icm, etc
I believe shbox's website has a guide on how to test the icm http://www.shbox.com
pop the hood late at night and check for wires arching, if not then change the plugs
SES light could be from deleting the EGR or AIR
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
ChrisFrez
Mar 22, 2015 09:12 AM
jp2002ls1
Jul 22, 2002 04:18 PM
