correct spark plug heat range?
Old May 13, 2008 | 09:19 PM
firstlast's Avatar
i am running ngk tr6's one heat range colder than stock gapped at .35 and they are carbon fouling, and that is causing my 02 sensors to foul, so i am wondering what heat range i should look at for my motor
Old May 13, 2008 | 10:57 PM
Those plugs shouldn't foul in a high compression application like yours. Many people use them in relatively stock engines when they are running nitrous, and they don't have problems with them fouling. I'd guess the problem is its running rich, and that's fouling the plugs and the O2 sensors.
Old May 13, 2008 | 11:01 PM
The Evans coolant does not require a high pressure cap because it is non-aqueous propylene glycol. The absence of water significantly lowers the vapor pressure of the coolant at very high temperatures, compared to the conventional water/ethylene glycol mix. Hence it does not require an 18psi cap.
Old May 14, 2008 | 01:32 PM
firstlast's Avatar
what happened first was my maf wasnt getting power then i fixed that, mabye that was what was causing it to run rich, then i replaced my left O2 sensor and it seemed to run better, now i have 2 new O2 sensors and i havent installed tham yet because i was afraid of fouling them because of the spark plugs, so if i take out and clean my plugs then install the new O2 sensors should it fix the problem?
Old May 15, 2008 | 01:34 PM
firstlast's Avatar
ok it is still running rough, i think its the gas because i just used the gas station down the street, and i always use shell, so im going to get all of the crappy gas out, and get some shell in it today
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
