Correct positioning of GM guideplates?
Old Jan 7, 2005 | 10:57 PM
stereomandan's Avatar
Well, I test fitted a cylinder with the new valvetrain, and the GM guideplates seem to have a decent amount of tolerance around the rocker stud hole. I can move them side to side a decent amount and wondered if there was a way to tell where the best position is. Do you just look at the rocker tip and position the guideplates so that it puts the rocker tip centered the best you can over the valve stem?
1.6 Pro Magnum, 7/16" stud, Non Self Aligning Roller Rockers
Comp 7/16" Studs
GM Guideplates
Comp Cam Hardened Pushrods
LT4 Springs
LT4 Retainers
LT4 Locks
Dan
Old Jan 9, 2005 | 12:21 PM
arnie's Avatar
Re: Correct positioning of GM guideplates?
Originally Posted by stereomandan
Well....Do you just look at the rocker tip and position the guideplates so that it puts the rocker tip centered the best you can over the valve stem?
Yes! But, more powa to ya, in your quest to get it correct.
Old Jan 9, 2005 | 12:57 PM
Thanks. I have it all installed now. Basically I slid the guideplates from the front against the side of the studs as I tightened the studs down. It's hard to explain. That means that at least all the guideplates were installed the same. By holding the guideplates against the stud, it kept the guideplate from being rotated when the studs were tightened.
The rocker tips were all right where they were supposed to be.
Dan
68camaroboltz
Oct 5, 2015 11:56 PM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
Fatdog2
Sep 16, 2015 11:04 PM
Aaront810
Sep 11, 2015 11:24 AM
