copper header gasket leaking
Old Sep 1, 2003 | 12:02 PM
med_reject's Avatar
I had paper gaskets which leaked, and i had them replaced, and they leaked, so I did some research and bought copper gaskets. I replaced the passenger side gasket myself, and now its leaking much worse.
I opened as much as I could to make sure the surfaces are clean and I couldnt see any bits of paper etc. left behind. I did this while the two end bolts were still on, so my visibility was limited. I made sure the bolts were really tight, but its still leaking bad.
I should have kept the old gasket to compare the sealing surfaces. Any suggestions, ideas??
thx
Old Sep 1, 2003 | 12:37 PM
96z's Avatar
96z
Get some felpro's and make sure the surface is very clean. Line it up and bolt em down...
Old Sep 1, 2003 | 12:39 PM
EviLBoX's Avatar
I had the same problem with copper gaskets, I couldn't get them to seal properly. Instead I went with some Fel-Pro gaskets as mentioned above and haven't had any leaks in nearly 2 years now.
Old Sep 1, 2003 | 12:47 PM
med_reject's Avatar
i think i figured it out
the copper gaskets i have are rounded squares, but it seems they should ahve given me one that has d-shaped holes. That must be the problem because i could see carbon on two corners of the gasket.
Old Sep 1, 2003 | 02:14 PM
ssbowtie1's Avatar
Personally I would get some dead sofl aluminum header gaskets. They are thick and soft, so they allow proper sealing of the headerss even if there are some manufactuing imprefections, which is usually why headers gaskets leak anyways.
Old Sep 1, 2003 | 02:24 PM
94formulabz's Avatar
Re: i think i figured it out
It does sound like the wrong gasket, my mr. gasket copperseals were definitly D shaped.
I still could not get them to seal though because the SLP headers had a larger port opening than the raised crush lip on the gasket. The crease where the port intersected with the raised crush area would leak. I ended up with the felpros, work great for me.
-brent
Old Sep 1, 2003 | 03:24 PM
revtime's Avatar
They have to be the D shaped ones, When I ordered mine they sent me the wrong ones twice.
I guess someone was thinking they would help me out and send me the round ones casue I have a small block chevy.
My copperseals have not leaked yet.
Old Sep 1, 2003 | 03:29 PM
jkipp84's Avatar
I gave the dead soft aluminum collector gaskets a shot when I had to drop my y-pipe last winter. Blew them both out within 1 month.. Just my experience. I don't think I'd use the header gaskets of this type.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
Jazsun
Dec 29, 2014 12:14 PM
