cooliong system
cooliong system
when do you have to bleed air out of the cooling system because i just did the tb bypass and i had the cap off do i need to bleed it or not and if so how do i do it thanks.
Any time you open up the system, as you did by pulling the hoses off the throttle body, you have to bleed the system. Follow the instructions on Shoebox's Tech Pages......
http://shbox.com/1/4th_gen_tech1.html
14
Aug 11, 2015 12:03 PM
